All,
I am trying to find the API call for putting in the splash message when we block a wireless user.
I can check the state of the wireless device:
But where can i find that message, and how do i change or add a message...
I need the API call for that (or HTML request, then i create my own call)
Best regards
ed
Check out the APIv1 endpoint POST /networks/{networkId}/clients/provision
https://developer.cisco.com/meraki/api-v1/#!provision-network-clients
For APIv0: https://developer.cisco.com/meraki/api/#!provision-network-clients
I check the page (we are still using V0) but cannot find anything that looks like sending the reason why we blocked the device.
Best regards
Ed
In Network-Wide -> Configure -> General, you can set a default block message for the network. This should then appear, when you provision the network client.
Unfortunately, I don't think there is an endpoint for updating it, so you'll probably have to set the default message, manually.
Also, if you need a special message for at certain client, you'll probably need to set it manually, aswell.
Hope that helps. 🙂
Ola,
Still looking for a way to change that blocked message. Can't find an API for the general nor the user message
If there was a way to create a policy with a message , then i would do it like that
I know some things can only be changed using the web page and not the API unfortunatlt
Cheers
Hi There,
Of course we can, however we have about 300+ networks.... Changing it using API is just a loop with Meraki API.
If there is gonna be a change in message, we have to do it all over again.....
That is why i would like the API instead of manual labour
Cheers
