In Network-Wide -> Configure -> General, you can set a default block message for the network. This should then appear, when you provision the network client.
Unfortunately, I don't think there is an endpoint for updating it, so you'll probably have to set the default message, manually.
Also, if you need a special message for at certain client, you'll probably need to set it manually, aswell.
Hope that helps. 🙂
LinkedIn :::
https://blog.rhbirkelund.dk/Like what you see? - Give a Kudo ## Did it answer your question? - Mark it as a Solution
🙂All code examples are provided as is. Responsibility for Code execution lies solely your own.
