Source IP and/or VLAN mismatch
MRMunemo
Hi All,
Please assist. I am seeing this on my Meraki MX80 events log and i am booted out from the machine on the LAN when connected to the machine remotely. What could be the cause of this and how can i resolve it. Could it be the cause of my internet slowdown?
Bruce
Just saw your comment at the end of the last post. There are a couple of articles about Axis camera that talk about them getting both an assigned IP address (static or DHCP) and an a 169.254.x.x address - this is likely what’s causing the errors you are seeing. It appears you can turn this behaviour off by disabling the ZeroConf setting in the cameras webpage.
13 Replies 13
169.254.x.x IP addresses are what your machine uses before it gets its DHCP address.  They are not routable and should be blocked from being forwarded.
You need to find out why your machine is not getting an IP address.
My machine has an IP:192.168.0.40
GW:.1
How can i block these IPs?
Is it what's causing this
KarstenI
It's not the PCs, The OUI AC:CC:8E is assigned to Axis. You have to control the IP-addressing of your cameras. As Philip mentioned, they probably do not get IPs assigned the way it should.
Could that cause the "bad gateway" error message? I noticed that when that error comes i wont be able to access my PC from outside(wan) and my PC times out when browsing the internet.
Bruce
As @PhilipDAth said, the 169.254.x.x are addresses automatically assigned by the device themselves (Automatic Private IP Address). You usually see these when a device is set for DHCP addressing but hasn’t received an address. You need to figure out what these devices are, and why they’re not getting an IP address for DHCP (assuming that’s the setup you intended). Are these devices in a separate VLAN? Is there a DHCP pool set up for that VLAN?
MRMunemo
I have only one default vlan set on the mx80.
The camera is actually getting an IP:
Bruce
Do you have a number of Axis cameras connected to your network?
Bruce
MRMunemo
Thank you.
MRMunemo
yes,i have.
Bruce
MRMunemo
Thank you.
MRMunemo
yes,i have
