I'm looking for an API and/or Python code that can give me all Orginazation networks (75+ sites) with all site devices and Clients (Endpoints).
Organization
Site NetworkName
Device Name
Clients
{Status, Last Seen, Description, Connection to, Recent SSID, Manufacturer, Port, VLan, MAC, IPv4}
I would like to run this at any time to give me snapshot of the Orginations per site network connectivity. If anyone has any help on retreiving this information in a json or csv format that would be outstanding.
Thank you!!
Check out the same scripts in the Meraki github. It would be easiest to start with something and then modify it.
https://github.com/meraki/automation-scripts
Check out this sample script, "aio_org_wide_clients_v1.py".
https://github.com/meraki/dashboard-api-python/blob/main/examples/aio_org_wide_clients_v1.py
PhilipDAth.. Thank you for your response. I have the same frustration as I have in my other question, I put in regarding https://community.meraki.com/t5/Developers-APIs/Snapshot-of-All-Orginazation-Networks-Wireless-Air-M... . I think Meraki has a development hole in their portal for not giving us the proper tools to manage an Orginazation/Network(s). Sort of the big picture reporting/dashboard aspect of the enterprise. Anyway, thank you for the github url - I'll check it out. Also, you should check out Todd Simmon's - https://youtu.be/P5JWxEUU544?si=ASVXHcvtXRfLDL0G and his github repo - https://github.com/toddhsimmons/
Given hindsight, I think a Graph based API might have been better (where you can construct queries for the data you want).
I don't see that as being a "hole in their portal".
getOrganizationNetworks , getNetworkClients with a Org small like yours it will take maybe a minute or 2 to run. Having Org-wide calls with "volatile" info such as client info is pretty hard to run on big orgs , that is one of the reason they don't exist.
I have code that may help you. This code lists clients for a 50+ network. I also have inventory code that drops everything (AP wise- not other equipment) into a spreadsheet for all for the network "AssetDataDump."
https://github.com/jadexing/Merakicode/blob/main/ListClients
Cheers.
Thank you for this response. This is very close to what I was looking for.
I have another quick question: I'm able to add fields like "Recent SSID" and "Manufacturer", but for some reason I couldn't add "Connect to", "Port", "VLAN" etc. I'm a Python newbie but I can usually find my way around code. Could you please explain why I can't grab this info from the client screen? Thanks again.
