Settings IoT Radio Settings and related settings via API
YoeriOppelaar1
Hi All,
For a healthcare customer, I need to setup the IoT radio's in the wireless configuration to catch the BLE clients and forwards their data via MQTT to a healthcare/patient alarming system. In the past couple of months we set this up (via GUI) and tested this over a couple of locations.
Now they want to continue for all their locations. We try to configure as much as possible via API.
Maybe I overlooked in the API documentation, but im unable to find how to set the IoT radio settings (via which API endpoints). I was able to find how to setup the MQTT broker itself within a network, but couldn't find how to set Bluetooth scanning to enable and how to set the remaining MQTT Telemetry Scanning and Bluetooth Telemetry settings.
if they exist, can someone please point them out to me.
Yoeri
2 Replies 2
Ryan_Miles
Meraki Employee All-Star
@YoeriOppelaar1 You can set the bluetooth scanning mode with this endpoint https://developer.cisco.com/meraki/api-v1/update-network-wireless-bluetooth-settings/
I don't believe there are endpoints yet for the more advanced parts of MR MQTT settings.
YoeriOppelaar1
Hi Ryan, thanks for pointing to the Bluetooth scanning, I will look into this one.
do you know or if not, who can clarify if the remaining calls are on the roadmap/backlog of meraki devs?
with. regards Yoeri
