SDK for claiming network devices fails
bly
Using meraki-node-sdk generates a fatal error when calling DevicesController.claimNetworkDevices.
This appears to be because the API is specified in meraki/openapi as returning an HTTP 200 for this request, even though the actual API behaviour returns no response payload (should be HTTP 204 in that case).
I reported this issue back in September 2019, however it appears it has gone ignored:
https://github.com/meraki/meraki-node-sdk/issues/1
We have worked around this issue in the meantime by calling the API without the assistance of the SDK, can you please advise whether we should expect a fix?
Additionally, if you are not monitoring GitHub issues for your repositories - can you please disable them to avoid confusion?
Actually, this was already fixed in the September release! Just update your SDK to the latest version,
(diff)
https://github.com/meraki/meraki-node-sdk/blob/a327f1bce7129066903ee924fd56f3c54571475e/lib/Controll...
5 Replies 5
BrechtSchamp
That's not good. @DexterLaBora , is this something you can take a look at?
Thanks for bringing this up. I've responded to the issue within GitHub.
- We are looking at fixing this from both an API and SDK perspective.
Cheers for the reply, good to know it's on the radar 🙂
(diff)
... egg on my face - thanks for the heads up, I'll make sure we've rolled forwards to the latest version!
