Request: Organisation-level Network Events Endpoint
david_n_m_bond
We are currently round-robining 2400 networks for a customer, querying ALL network events (not just the bad ones).  We would like to significantly reduce the load that we put on the API.
Please could we have a call (e.g.):
  • /organisation/{organisationId}/events
... that returns the equivalent of the following, but for all networks:
  • /networks/{networkId}/events
Author, https://www.nuget.org/packages/Meraki.Api/
5 Replies 5
sungod
If you are querying repeatedly in order to get the latest events, especially critical ones, then rather than using the API it might be worth using webhooks instead.
david_n_m_bond
Nice idea, but we need all events, not just the bad ones.
RaphaelL
Aren't all event logs sent to a syslog server ? Or is there some categories that are only available via API / Dashboard ?
sungod
Certainly most go to syslog, though the chart on the linked page suggests not quite everything that the API can get, for instance "Proactive alerts for critical events".
https://documentation.meraki.com/General_Administration/Monitoring_and_Reporting/Meraki_Device_Repor...
david_n_m_bond
Thanks @RaphaelL, but we need to reliably receive all events without missing any, so must poll for them ("pull") rather than receiving syslog events ("push").
