Question on using python for automation of moving sites from this template to other template
JH3
Hi, I am currently researching on how to use the python script to automate of moving the sites that have existing configuration from the old configuration template to a new configuration template. Is it possible to use automation for this? Thanks in advance.
1 Reply 1
GreenMan
Yes - you can bind and unbind Networks to/from Templates with the following endpoints:
https://developer.cisco.com/meraki/api-v1/#!bind-network
https://developer.cisco.com/meraki/api-v1/#!unbind-network
I don't believe there's a single endpoint to move a Network directly from one Template to the other, as can be done through the Dashboard:   https://documentation.meraki.com/General_Administration/Templates_and_Config_Sync/Managing_Multiple_...
