Powershell POST Script - Help
USMC92
Trying to execute a POST script in PS, below is the function.  When I run the script I'm receiving a 308 error.
#Create a new dashboard administrator
function Post-MerakiAdmin {
param (
[string]$organizationId,
[string][Parameter(Mandatory=$true)]$name,
[string][Parameter(Mandatory=$true)]$email,
[string][Parameter(Mandatory=$true)]$access,
[string]$tags = ""
if (!$organizationId){
$orgIds = Get-MerakiOrganizations
$i = 0
ForEach($orgId in $orgIds){
Write-Host "$i $($orgId.name)"
$i++
Write-Host "`n"
While (!$organizationId){
$choice = Read-Host -Prompt "Select Organization"
$organizationId = $orgIds[$choice].id
$params = @{
name = $name
email = $email
orgAccess = $access
tags = $tags
$json = $params | ConvertTo-Json
$request = Invoke-RestMethod -Uri "$($api)/organizations/$($organizationId)/admins" -Method POST -Headers $header -Body $json -ContentType $contentType
return $request
Any assistance is appreciated.
8 Replies 8
AlexG
What's the value of the $api variable? My guess would be that you've got a malformed URI. The 308 errors I've gotten in the past have been related to using the wrong URL. The API docs say to use the prefix: https://api.meraki.com/api/v0 before the /organizations/... bit. You could always just 'Write-Host $uri' before you call Invoke-RestMethod to see what it's sending.
USMC92
Finally figured out the issue.  On POST commands I had to change the URL, after reviewing multiple sites on the issue.  The $api variable equaled https://api.meraki.com........, and what I had to do was create a 2nd variable ($postapi) and point it to the redirected URL.   Once that was done script ran without error.
LauraZ
Can you please give me an example? I'm having the exact same error on any Meraki POST call using PowerShell.
joshand
Meraki Alumni (Retired)
Here is an example Powershell script showing how to manage the 308. I don't remember if everything in here is working or not, but it should give you some ideas of things to do.
Disclaimer in advance: Powershell is not my forte, so apologies for the questionable quality of the code.
[CmdletBinding()]
Param (
    [string] $name,
    [string] $organization,
    [string] $network,
    [string] $device,
    [string] $port,
    [string] $psk,
    [switch] $getorgs = $false,
    [switch] $getnets = $false,
    [switch] $getdevs = $false,
    [switch] $gethealth = $false,
    [string] $newnet = $false,
    [string] $newdev = $false,
    [string] $newwhd = $false,
    [string] $setwhalert = $false,
    [string] $setssid = $false,
    [switch] $setssiddns = $false,
    [string] $setporttag = $false,
    [string] $setportvlan = $false,
    [string] $timespan = $false,
    [switch] $help = $false
New-Variable -Scope global -Name headers
$global:headers = @{
	"Content-Type" = "application/json"
	"Accept" = "application/json"
	"X-Cisco-Meraki-API-Key" = "1234567890abcdefghijklmnopqrstuvwxyz1234"
New-Variable -Scope global -Name base_url
$global:base_url = "https://api.meraki.com/api/v0"
add-type @"
using System.Net;
using System.Security.Cryptography.X509Certificates;
public class TrustAllCertsPolicy : ICertificatePolicy {
    public bool CheckValidationResult(
        ServicePoint srvPoint, X509Certificate certificate,
        WebRequest request, int certificateProblem) {
        return true;
$AllProtocols = [System.Net.SecurityProtocolType]'Ssl3,Tls,Tls11,Tls12'
[System.Net.ServicePointManager]::SecurityProtocol = $AllProtocols
[System.Net.ServicePointManager]::CertificatePolicy = New-Object TrustAllCertsPolicy
Function Convert-FromUnixDate ($UnixDate) {
   [timezone]::CurrentTimeZone.ToLocalTime(([datetime]'1/1/1970').AddSeconds($UnixDate))
function callGETService {
	$uri = $global:base_url + $args[0];
	Write-Host 'Calling URI (GET):' $args[0];
	try {
		$response = Invoke-RestMethod -Method GET -Uri $uri -Headers $global:headers
	} catch {
		$ret = @{
			"statuscode" = $_.Exception.Response.StatusCode.value__
			"statusmsg" = $_.Exception.Response.StatusDescription
		$response = $ret | ConvertTo-Json
	return $response
function callPOSTService {
	$json = $args[1] | ConvertTo-Json
	Write-Host 'Calling URI (POST): ' $args[0];
	try {
		$response = Invoke-RestMethod -Method POST -Uri $uri -Body $json -Headers $global:headers
	} catch {
		$ret = @{
		$response = $ret
	return $response
function callPUTService {
	Write-Host 'Calling URI (PUT): ' $args[0];
	try {
		$response = Invoke-RestMethod -Method PUT -Uri $uri -Body $json -Headers $global:headers
 	} catch {
		$ret = @{
		$response = $ret
	return $response
function find308dest {
	# Powershell really seems to be unfriendly with 308/Permanent Redirect given by
	#  Dashboard when making POST/PUT requests. Prior to issuing a POST/PUT, send the
	#  URL through this function, which will make a GET to determine the proper host
	#  to send the API request to.
	$fix_uri = $args[0] + $args[1];
	$fix_res = Invoke-WebRequest -Method GET -Uri $fix_uri -Headers $global:headers -MaximumRedirection 0 -ErrorAction SilentlyContinue
	$fix_url = $fix_res.Headers.Location
	$uri = $fix_url -replace $args[1],""
	return $uri
function getHelp {
	Write-Host "powershell -file mcmd.ps1 -action [name] [options]"
	Write-Host ""
	Write-Host "ACTION"
	Write-Host ""
	Write-Host "     -getorgs"
	Write-Host "          Returns a list of Organizations that the provided API Key has access to."
	Write-Host ""
	Write-Host "     -getnets"
	Write-Host "          Returns a list of Networks configured in the provided Organization."
	Write-Host "          Used together with -organization"
	Write-Host ""
	Write-Host "     -getdevs"
	Write-Host "          Returns a list of Devices configured in the provided Network."
	Write-Host "          Used together with -network"
	Write-Host ""
	Write-Host "     -newnet ""network name"""
	Write-Host "          Create a new network in a given Organization."
	Write-Host ""
	Write-Host "     -newdev serial-number"
	Write-Host "          Claim a device into a given Network."
	Write-Host ""
	Write-Host "     -newwhd destination-url"
	Write-Host "          Creates a new Webhook Destination; Returns the Webhook ID."
	Write-Host ""
	Write-Host "     -setwhalert webhook-id"
	Write-Host "          Enable Configuration Change Alerts for a Webhook with the provided ID."
	Write-Host ""
	Write-Host "     -setssid ""ssid name"""
	Write-Host "          Configures a SSID for PSK with a provided Pre-Shared Key."
	Write-Host "          Used together with -network and -psk"
	Write-Host ""
	Write-Host "     -setssiddns"
	Write-Host "          Configures the Layer 3 Firewall for the first SSID to allow only Umbrella DNS."
	Write-Host ""
	Write-Host "     -setporttag ""tag-name"""
	Write-Host "          Sets a tag on a specfied switch port."
	Write-Host "          Used together with -network and -port"
	Write-Host ""
	Write-Host "     -setportvlan ""vlan-id"""
	Write-Host "          Sets a VLAN on a specfied switch port."
	Write-Host ""
	Write-Host "OPTIONS"
	Write-Host ""
	Write-Host "     -organization"
	Write-Host "          Specify the Organization to apply the action to."
	Write-Host ""
	Write-Host "     -network"
	Write-Host "          Specify the Network to apply the action to."
	Write-Host ""
	Write-Host "     -device"
	Write-Host "          Specify the Device to apply the action to."
	Write-Host ""
	Write-Host "     -psk"
	Write-Host "          Specify the PSK to use when configuring a SSID."
	Write-Host ""
	Write-Host "     -port"
	Write-Host "          Specify the Port to use when configuring a switch port."
	Write-Host ""
# get all organizations
function getOrgs {
	$res = callGETService '/organizations'
	Foreach ($x in $res)
		Write-Host "* $($x.id) - $($x.name)"
# get all networks
function getNets {
	$uri = '/organizations/' + $args[0] + '/networks';
	$res = callGETService $uri;
# get all devices
function getDevs {
	$uri = '/networks/' + $args[0] + '/devices'
		Write-Host "* $($x.serial) - $($x.model) - $($x.mac)"
# add network
function newNet {
	$network = @{
		name=$args[0]
		timeZone='Etc/GMT'
		type='switch appliance wireless'
	$testuri = "/organizations"
	$newhost = find308dest $global:base_url $testuri
	$uri = $newhost + '/organizations/' + $args[1] + '/networks'
	$res = callPOSTService $uri $network
	$id = $res.id
	$sc = $res.statuscode
	if ($sc -eq $null) {
		Write-Host 'New network' '"'$id'"' 'created.'
	} else {
		$rout = $res | ConvertTo-Json
	        Write-Host ""
		Write-Host $rout
# add device
function newDev {
	$device = @{
		serial=$args[0]
	$testuri = "/networks/" + $args[1]
	$uri = $newhost + '/networks/' + $args[1] + '/devices/claim'
	$res = callPOSTService $uri $device
	$id = $res.id
		Write-Host 'New device' '"'$args[1]'"' 'claimed.'
	} else {
	        Write-Host ""
		Write-Host $rout
# add webhook destination
function newWebhookDest {
	$wh = @{
		name='Webhook'
		sharedSecret=''
		url=$args[0]
	$uri = $newhost + '/networks/' + $args[1] + '/httpServers'
	$res = callPOSTService $uri $wh
	$id = $res.id
		Write-Host 'New webhook destination' '"'$id'"' 'created.'
	} else {
	        Write-Host ""
		Write-Host $rout
# set webhook alert for config changes
function setWebhook {
	$wh = @{
		defaultDestinations=@{
			httpServerIds=@($args[0])
		alerts=@(@{
			type='settingsChanged'
			enabled='true'
	$uri = $newhost + "/networks/" + $args[1] + "/alertSettings"
	$res = callPUTService $uri $wh
	$id = $res.number
		Write-Host "Configuration update alerts enabled for webhook" '"'$args[0]'"' "."
	} else {
	        Write-Host ""
		Write-Host $rout
# configure SSID
function setSsid {
	$ssid = @{
		name=$args[0]
		enabled='true'
		authMode='psk'
		encryptionMode='wpa'
		wpaEncryptionMode='WPA2 only'
		psk=$args[2]
	$uri = $newhost + "/networks/" + $args[1] + "/ssids/0"
	$res = callPUTService $uri $ssid
	$id = $res.number
		Write-Host "SSID" '"'$id'"' " configured."
	} else {
	        Write-Host ""
		Write-Host $rout
# configure SSID L3 FW to only allow Umbrella DNS
function setSsidDns {
	$ssid = @{
		rules=@(
				comment='Allow Umbrella DNS'
				policy='allow'
				protocol='udp'
				destPort='53'
				destCidr='208.67.222.222/32'
				policy='allow'
				protocol='udp'
				destPort='53'
				destCidr='208.67.220.220/32'
				comment='Block Other DNS'
				policy='deny'
				protocol='udp'
				destPort='53'
				destCidr='any'
	$testuri = "/networks/" + $args[0]
	$uri = $newhost + "/networks/" + $args[0] + "/ssids/0/l3FirewallRules"
	$id = $res.number
		Write-Host "DNS Restrictions set on SSID."
	} else {
	        Write-Host ""
		Write-Host $rout
# configure tag on switch port
function setPortTag {
	$port = @{
		tags=$args[0]
	$testuri = "/devices/" + $args[1] + "/switchPorts"
	$uri = $newhost + "/devices/" + $args[1] + "/switchPorts/" + $args[2]
	$res = callPUTService $uri $port
	$id = $res.number
		Write-Host "Tag" '"'$args[0]'"' "added to port" '"'$args[2]'"' "."
	} else {
	        Write-Host ""
		Write-Host $rout
# configure vlan on switch port
function setPortVlan {
	$port = @{
		type='access'
		voiceVlan=''
		vlan=$args[0]
	$id = $res.number
		Write-Host "Port" '"'$args[2]'"' "set as Access VLAN" '"'$args[0]'"' "."
	} else {
	        Write-Host ""
		Write-Host $rout
# get wireless health
function getWirelessHealth {
	$tsend = [int64](([datetime]::UtcNow)-(get-date "1/1/1970")).TotalSeconds
	$offset = 3600 * $args[1]
	$tsstr = $tsend - $offset
	$uri = '/networks/' + $args[0] + '/connectionStats?t0=' + $tsstr + '&t1=' + $tsend
	$total = $res.assoc + $res.auth + $res.dhcp + $res.dns + $res.success
	$ftotal = $res.assoc + $res.auth + $res.dhcp + $res.dns
	Write-Host "Wireless Health Information"
	Write-Host "(Last $($args[1]) Hours)"
	Write-Host "---------------------------"
	Write-Host "     Total Connections: $($total)"
	Write-Host "  Association Failures: $($res.assoc)"
	Write-Host "Authorization Failures: $($res.auth)"
	Write-Host "         DHCP Failures: $($res.dhcp)"
	Write-Host "          DNS Failures: $($res.dns)"
	Write-Host "                      ------"
	Write-Host "    Failed Connections: $($ftotal)"
	Write-Host "Successful Connections: $($res.success)"
	Write-Host ""
	$uri = '/networks/' + $args[0] + '/failedConnections?t0=' + $tsstr + '&t1=' + $tsend
	$count = 0
    Write-Host "Last 10 Failures"
		$curtime = Convert-FromUnixDate $x.ts
		Write-Host "* Client $($x.clientMac) failed at $($curtime). Cause: $($x.type) ($($x.failureStep))"
		$count++
		if ($count -eq 10) {
			break
If ($help -eq $true) {
	getHelp
} ElseIf ($getorgs -eq $true) {
	getOrgs
} ElseIf ($getnets -eq $true) {
	getNets $organization
} ElseIf ($getdevs -eq $true) {
	getDevs $network
} ElseIf ($gethealth -eq $true) {
	getWirelessHealth $network $timespan
} ElseIf ($newnet -ne $false) {
	newNet $newnet $organization
} ElseIf ($newdev -ne $false) {
	newDev $newdev $network
} ElseIf ($newwhd -ne $false) {
	newWebhookDest $newwhd $network
} ElseIf ($setwhalert -ne $false) {
	setWebhook $setwhalert $network
} ElseIf ($setssid -ne $false) {
	setSsid $setssid $network $psk
} ElseIf ($setssiddns -eq $true) {
	setSsidDns $network
} ElseIf ($setporttag -ne $false) {
	setPortTag $setporttag $device $port
} ElseIf ($setportvlan -ne $false) {
	setPortVlan $setportvlan $device $port
} Else {
	getHelp
MarkD_BT
here is my method of dealing with redirects on PUT or POST calls. Incase of assistance.
$resource = "https://api.meraki.com/api/v0/networks/$networkId/devices/$serial"
$redirect = Invoke-WebRequest -Uri $resource -MaximumRedirection 0 -Method PUT -Header $header -Body $body
if ($redirect.StatusCode -eq 308)
$resourceRedirect = $redirect.Headers.Location
Invoke-WebRequest -Uri $resourceRedirect -MaximumRedirection 0 -Method PUT -Header $header -Body $body
LauraZ
Thank you both @joshand and @MarkD_BT
I read somewhere else that instead of using the base URL https://api.meraki.com/api/v0, just use the redirect link you see when you work on your dashboard and follows the pattern: 'https://nXXX.meraki.com/api/v0'
However what you explained is so much cleaner.
MarkD_BT
Hey @LauraZ
glad it helped if your working against 1 organisation it's fine replacing the url, but If you have multiple orgs then this causes more issues. So I find it easier to use the base url and script a redirect so you can handle all orgs you might look after. Good luck with your scripting.
David-API
https://github.com/immolate/MerakiAPI
This is my self designed code... And though fairly messy. All the functions work.
You may have some answers to help you there. your $request = statement looks.. I can't decipher what it's doing. But maybe mine will help you?
