I work a lot with APIs. And regardless of the language, the one thing in common is JSON.
The thing with JSON is that it's really flexible, but can be tedious to parse or view the way you want.
I've spent more hours looping through JSON than I want to count, just to print out some CSV file or pull out a set of data for some other application.
So, instead of building these one-off scripts and functions all the time, I built a solution that will help make sense of complex JSON.
JSON Magic
- Input JSON
- Query w/ JSONata expressions
- Tableify
- Export JSON/CSV/HTML
There are a few versions of this HTML/JS app.
GitHub Code
Progressive Web App (installable as Chrome app)
Demo
Embedded Postman Visualization
Get the new Dashboard API v1 Postman Collection w/ JSON Magic Visualization
To really take advantage of this tool, I suggest you set aside a few hours to learn the basics of JSONata
This is still a work in progress, but it's already helped me a ton as I develop. I plan on cleaning up a few things now that I have a better understanding of the unique environments that I can shove this HTML/JS project in. Hope this helps you and let me know your thoughts.
