Postman and Meraki API - newer collections are not working - receive 404 results
Update: Issue resolved, un-installed postman and updated the collections.
I have been having difficulty running the newer API's released viaPostman. No matter how I try to execute using the newer collections it never returns anything.
When I switch back to an older collection - it executes fine. Same Cisco API key, same global variables.
I noticed that the OpenAPI standard changed some things. For example, when retrieving networks within an organization
 Old API calls looked like this:
<a href="<a href="https://api.meraki.com/api/v0/organizations/[organizationId]/networks" target="_blank">https://api.meraki.com/api/v0/organizations/[organizationId]/networks</a>" target="_blank"><a href="https://api.meraki.com/api/v0/organizations/[organizationId]/networks</a" target="_blank">https://api.meraki.com/api/v0/organizations/[organizationId]/networks</a</a>>
 New API calls looked like this:
<a href="<a href="https://api.meraki.com/api/v0/organizations/:organizationId/networks?configTemplateId=" target="_blank">https://api.meraki.com/api/v0/organizations/:organizationId/networks?configTemplateId=</a>" target="_blank"><a href="https://api.meraki.com/api/v0/organizations/:organizationId/networks?configTemplateId=</a" target="_blank">https://api.meraki.com/api/v0/organizations/:organizationId/networks?configTemplateId=</a</a>>
The brackets vs the colon is the only obvious difference, yet when I execute the same commands in Postman one is successful while the other isn't.
My problem is that while I like that the older API collections work, there are new things added that I want to utilize, but I cannot seem to get to work. What am I missing other than being dense? I'm not a developer, so any help would be great.
I've also attached some screenshots. new.pngNewer collection
old.pngOlder collection
2 REPLIES 2
Re: Postman and Meraki API - newer collections are not working - receive 404 results
Watching for a response, curious as well.
In case you were still waiting for the response @G_ControlScan ...
@bshoults82 updated the initial post saying that he solved it by:
