Hello!
Currently I'm using an ansible playbook (paired with the cisco.meraki collection) to disable a setting in a network. When I try to do it with a certain network however, I get the following error:
{"changed": false, "msg": 404, "response": "OK (unknown bytes)", "status": 404, "url": "https://api.meraki.com/api/v1/organizations/7087539913.../configTemplates"}
The module that I'm using is "cisco.meraki.meraki_network", so I never explicitly called the "configTemplates" endpoint, but I kept digging. I manually retrieved the info for the network that I want to configure and I noticed that the ID for its container organization is indeed "7087539913...". When I tried retrieving the info for the "7087539913..." organization however, I got a 404 response. Maybe the organization was not API enabled? Checked using the "getOrganizations" endpoint and it is API enabled.
What could be happenning here? The organization that I want to retrieve info from is API enabled, but when I tried to use the "getOrganization" endpoint, I get a 404 response back. I'm certain that my API key should be able to retrieve all info from the Meraki API as well. Does anybody know what could be going wrong?
