I am currently working on a simple script that provides a user-friendly interface to automatically modify an entire network static IP devices DNS configuration.
Here is the repository if you want to check it out & test it :
https://github.com/ThibautMatzke/meraki-automation-dns
On a previous script, I used to test out the api_key validity by using the function meraki.myorgaccess(api_key), but since apiV1, I cannot find any other way than trying to get the organization list with the provided API key.
This is what I currently do :
# Creates a persistent Meraki Dashboard API session with the given api_key
self._dashboard = meraki.DashboardAPI(api_key=api_key)
try:
# Tries a function to see if the API Key is valid
self._dashboard.organizations.getOrganizations()
# Return true the key is valid
return True
# Catches the error if the API Key isn't valid
except meraki.APIError as e:
# Prints the error message
print(e)
# Returns false if the key is invalid
return False
Does anyone have a better way of testing an api_key validity ?
Also, I would like to share this script on Cisco Code Exchange, but since I am totally new, do you have any best practices for this ? Should I wait to implement new features before submitting it ?
Thank you in advance for your answers / feedback !
