Network Device Loss and Latency History - response is empty []
Maria97
I am very new to the Meraki API, and am trying to get the latency for a specific device, but when I ran the request it returns an empty list, even though the response is 200. I'm not sure what I am doing wrong. Here's my code:
headers = {
        'X-Cisco-Meraki-API-Key': MERAKI_API_KEY,
        'Content-Type''application/json',
r = requests.get(f"https://api.meraki.com/api/v0/networks/{net_id}/devices/{serial_num}/lossAndLatencyHistory?uplink=wan1&ip=1.2.3.4", headers=headers)
print(r)
print(r.text)
OUTPUT:
<Response [200]>
network id and serial are  stored in those variables, and the ip address is different.
I appreciate any help.
Edgar-VO
Hi there,
I think you require also the timespan as a parameter. I use the same calls with API in python. I get the right result.
I put a part of my python code in it... Maybe you can use it.
        my_serial = my_device['serial']
        my_dest = {}
        # Get destination IP address which it pings
        my_dst_mon = dashboard.connectivity_monitoring_destinations.getNetworkConnectivityMonitoringDestinations(my_network_id)
        my_dest = my_dst_mon['destinations']
        try:
            my_device_name = my_device['name']
        except:
            my_device_name = my_device['serial']
        # Get first destination IP address
        for i in my_dest:
            my_dst_ip = i['ip']
            break
        param = {}
        param['timespan'] = 200
        my_latency_results = dashboard.devices.getNetworkDeviceLossAndLatencyHistory(my_network_id,my_serial,my_dst_ip,**param)
        my_network_uplink = dashboard.uplink_settings.getNetworkUplinkSettings(my_network_id)
Edgar-VO
On small addition....
with the line added
my_latency = my_latency_results[-1]
You get the latest latency record
Cheers
Ed.
rhbirkelund
You'll also need to convert the reply, since it is returning an object with json. Try including this;
import json
from pprint import pprint
r = requests(...)
if r.status_code == 200:
   rjson = r.json()
   pprint(rjson)
else:
   raise SystemExit(f"Unexpected status code {r.status_code}")
Edgar-VO
actually, there is no need for that...
If you do a
print(my_latency_results)
Then you get all the results
If you use
print(my_latency) then you get the latest result which might look like this
    "startTime": "2018-10-09T22:20:27Z",
    "endTime": "2018-10-09T22:21:27Z",
    "lossPercent": 0,
    "latencyMs": 44
and the latency = my_latency['latencyMs']
and loss will be : loss = my_latency['lossPercent']
