How to pass array for includedEventTypes
boomi
Not quite sure how to do this, I would like to specifiy "vrrp" and "dhcp" as the included event types. I would have thought that this is correct, but it returns nothing, as if it's interpreting it as the string literal 'vrrp,dhcp':
{{API}}/networks/{{netID}}/events?includedEventTypes[]=vrrp,dhcp&productType=appliance
If I try the following instead, it applies the last filter only (dhcp):
{{API}}/networks/{{netID}}/events?includedEventTypes[]=vrrp&productType=appliance&includedEventTypes[]=dhcp
I also tried moving the productType to the end, and including it after each event type, just in case it mattered.
I have verified that both vrrp and dhcp return events when specified alone.
chengineer
Meraki Alumni (Retired)
Your second request there has the correct format (the positions of the parameters do not matter), but you may need to also include perPage so you do not miss any events of a second category that are on a different page.
This works for me:
https://n7.meraki.com/api/v1/networks/L_566890603095268587/events?includedEventTypes[]=vrrp&productT...
Solutions Architect @ Cisco Meraki | API & Developer Ecosystem
chengineer
This works for me:
boomi
Yep, that was it, I forgot about the pagination. Thanks!
Frank-NL
Thank you 🤙
