NPM Package incorrect URL
bly
A small problem, however the NodeJS package you publish to NPM contains an invalid URL for the project sources, visible here: https://www.npmjs.com/package/meraki
Without this, users of package repositories such as npm may have difficulty finding the correct source repository to contribute issues and bug requests.
I reported this issue back in November 2019, however it appears it has gone ignored:
https://github.com/meraki/meraki-node-sdk/pull/3
Additionally, if you are not monitoring GitHub pull requests for your repositories - can you please disable them to avoid confusion?
Seems like reasonable ideas @chengineer .
chengineer
Meraki Alumni (Retired)
Thanks for the heads-up @PhilipDAth, and also tagging my teammate @DexterLaBora
Solutions Architect @ Cisco Meraki | API & Developer Ecosystem
Cheers guys 🙂
