Multiple API calls using data from 1st call...
sambo
I'm using this API call using python:
import requests
import json
url = "https://api.meraki.com/api/v1/organizations"
payload={}
headers = {
'X-Cisco-Meraki-API-Key': 'xxxxxxxxxx
response = requests.request("GET", url, headers=headers, data=payload)
r = json.loads(response.text)
for organizations in r:
print(organizations['name'] + ' ' + organizations['id'])
The output is what I'm looking for.
What I need to do now is to be able to use the organization id to then call all the networks in each org:
eg.....
API CALL 1....url = "https://api.meraki.com/api/v1/organizations"
(THIS WILL PRINT OUT ALL ORGS I HAVE ACCESS TO)
Then use these ID's in the next calls until no ID's are left...
If anyone has any advise or a script they have used that would be great.
Sam
6 REPLIES 6
If you use the Meraki Dashboard API library:
https://developer.cisco.com/meraki/api-v1/
Then you can use some code like this:
	# Search for the org
	orgs = dashboard.organizations.getOrganizations()
	for org in orgs:
		if org['name'] == orgName:
			orgId=org['id']
			break;
	if orgId == None:
		print("Invalid organization name supplied: "+orgName)
		exit(-1)
If I run this after the 1st API call it fails:
NameError: name 'dashboard' is not defined
I'm just not sure how to link the API query with this and then use it for the 2nd query.
Sam
Edgar-VO
First create a session like :
dashboard       = meraki.DashboardAPI(api_key)
my_org = dashboard.organizations.getOrganizations()
for org in my_org:
        org_id = org['id']
        print(org['name'])
sambo
If this is the script that calls the ORG names:
#SCRIPT THAT CALLS THE ORGS THEN ONLY PRINTS THE ORG NAME ONLY
import requests
import json
payload={}
headers = {
'X-Cisco-Meraki-API-Key': 'xxxx'
print(organizations['name'])
Where does the create session from below get inserted?
for org in my_org:
        org_id = org['id']
        print(org['name'])
John-K
@sambo the suggestions above are correct and rely on installing and using the Python SDK.
Please read the Python SDK readme for instructions: https://github.com/meraki/dashboard-api-python
sambo
I'm reading and learning now, Thanks!
Sam
