While Meraki Dashboard does not have a dedicated option for Port Security violation alerts or direct STP error alerts, you can still monitor these events through the Event Log and set up alerts for link changes, port down events, or other relevant switch status changes. These indirect methods will help you stay informed about port issues, security violations, and STP-related events.
For more advanced monitoring and custom alerting, you could explore integrating Meraki’s Dashboard API or a third-party network monitoring tool that supports Meraki's logs.
If you need more advanced monitoring or integration with other systems (such as SIEMs, NMS tools, or custom dashboards), you can leverage Meraki’s Dashboard API. Through the API, you can retrieve information about port security events, STP status, and other network parameter
