Meraki API timeout after 120 seconds
RaphaelL
Hi ,
I have been experimenting lots of timeouts with api.meraki.com recently.
I have tried with both my personal PC on my home network AND from my work PC from corporate network.
I was able to take a pcap of what is happening :
On packet 6448 Meraki ACK my api call but then 120 seconds later Meraki tears the connection due to inactivity... but I was waiting on them to retrieve me the info...
Python requests module returns : requests.exceptions.ConnectionError: ('Connection aborted.', RemoteDisconnected('Remote end closed connection without response'))
The API call made seems to always be : '{0}/networks/{1}/devices'.format(str(base_url_v1), str(networkID)). It's never the same network but they are in the same Org ( Org isnt specified here )
I'm not using the SDK , I'm using a simple function with requests.
def getNetworkDevice(apikey, networkID):
    geturl = '{0}/networks/{1}/devices'.format(str(base_url_v1), str(networkID))
    dashboard = requests.get(geturl, headers=headers,timeout=600)
    result = __returnhandler(dashboard.status_code, dashboard.text)
    return result
Has anyone ever seen those kind of issue ? I'm about to open a ticket. I know I could simply use a smaller timeout than Meraki and retry until I get a response , but this is only a temp fix.
7 REPLIES 7
Re: Meraki API timeout after 120 seconds
I don't think I am understanding correctly.
There is no way that a call to "{0}/networks/{1}/devices" would take 2 minutes to respond.  I haven't used the REST API in a long term (I mostly used the Python SDK), and I never get timeouts.  Never.
Is the issue that you make the API call successfully, and then sometime later you are getting this exception?
Have you tried the sample code that the developer website creates?
https://developer.cisco.com/meraki/api-v1/#!get-network-devices
import requests
url = "https://api.meraki.com/api/v1/networks/{networkId}/devices"
payload = None
headers = {
    "Content-Type": "application/json",
    "Accept": "application/json",
    "X-Cisco-Meraki-API-Key": "xxx"
response = requests.request('GET', url, headers=headers, data = payload)
print(response.text.encode('utf8'))
RaphaelL
I know it doesn't make sense that the query would take 2 minutes to respond but the pcap is not lying. Meraki acknoledges the API Call but never returns anything then after 120 seconds closes the session.
I have used lots and lots of differents calls but it seems to be only affecting this one.
Sometimes it will time out after 60 networks , sometimes more. But I can reproduce the issue all the time.
My code is very similar to the snippet on the developer website.
I have retried the same network and got it to work :
350 - Meraki ACK the API request
370 - Sends the Data back
371,375,376 TCP Session ending. Client caused the session ending.
Have you got an org on another shard you can test with?
Maybe that one shard has an issue.
Alisdair85
Hi @RaphaelL there is a known issue with Meraki Development/Engineering with api.meraki.com I have had a case open since July for the same timeout behaviour, their recommended workaround for the moment is to use the node/shard FQDN for that customer / Org i.e n<123>.meraki.com we have coded this into all out apps and not had any performance challenges.
Cheers
Ali
RaphaelL
Ohhhh !
I will try this right away
RaphaelL
Using the shard URL instead of using "api.meraki.com" solves the issue !
I will open a ticket and assign a priority on it.
Thanks !!
Alisdair85
No problem at all, happy to help, yes makes sense to raise a case too
