Meraki Webhook and Pagerduty hide "shared secret"
Mikanator
we have the meraki and pagerduty integration working
using the custom code provided by cisco for the event transformation.
we are using the "shared secret" as a filter for incoming alerts.
now we are wanting to hide from the incident payload so that users/ticket do not see the "shared secret"
anyone have any luck in doing this?  we have tried the splice function and it did not work...
here is the current code:
/ Consume Meraki Alert via Webhook
var body = PD.inputRequest.body;
// Set Alert Severity
var severity = "warning";
// critical
// error
// warning
// info
// unknown
if(body.alertType == "Settings changed") {severity = "info";}
if(body.alertType == "Motion detected") {severity = "info";}
if(body.alertType == "Network usage alert") {severity = "warning";}
if(body.alertType == "APs went down") {severity = "critical";}
if(body.alertType == "Uplink status changed" && !body.alertData.uplink) {severity = "critical";}
var event_type = "PD.Trigger";
//PD.Trigger - use this event type to trigger a new event
//PD.Resolve - use this event type to resolve a triggered incident
//PD.Acknowledge - use this event type to acknowledge a triggered incident
//if (body.alertType == "APs came up") {event_type="PD.Resolve";}
//var title = body.alertType+": "+body.networkName;
var description = body.alertType+": "+body.networkName;
// Format payload
var cef_event = {
    event_type: event_type,
      //title: title,
      description: description,
    severity: severity,
    source_origin: body.networkId,
    dedup_key: body.alertId,
    service_group: body.organizationId,
      event_action: PD.Trigger,
      details: body
// Check secret and store event
const SECRET = "xxx123";
if(body.sharedSecret == SECRET){
   PD.emitCEFEvents([cef_event]);
Brilliant!
the idea worked.
the actual syntax is:
   body.sharedSecret = null                <----- Blank secret from data (no brackets)
4 REPLIES 4
jdsilva
I've not used the code you're referring to before, and honestly I only really know a bit of python, but it seems to me that if you were to blank out the secret before you do anything else with the data tat should do the trick?
   body.sharedSecret = <NULL>                <----- Blank secret from data
Brilliant!
the idea worked.
jdsilva
Woohoo!
My example was meant as pseudocode since I didn't have any idea what a null character would be in whatever language that actually is 🙂
Well thank you soooo much!
simplicity at its best!
