Meraki Sensor API - fetching latest sensor reading by serial
Rebry
Hi
For some reason ive figured i'd make an Apple homekit plugin for homebridge featuring the Meraki MT sensors.
I guess ive got to much time on my hand.
But!
Im unable to fetch the latest information based on serials.
the API keeps returning (in postman) :
    "errors": [
        "'serials' must be an array"
Could someone point me in the direction of the correct formatting for the so-called array i need to send?
RaphaelL
Hi , could you provide us which endpoint are you using ?
I'm guessing the syntax should be something like that : serials[]="xxxx-xxxx-xxxx"
5 Replies 5
RaphaelL
Rebry
Yep! thats it @RaphaelL
Ive tried the serials=[] as postman had that as an example in the postman themplate.
And no matter how i formatted the array on the right side, it complained.
first try with https://api.meraki.com/api/v1/organizations/ORGID/sensor/readings/latest?serials[]=SERIAL and it worked 😄
Thanks!
RaphaelL
Excellent ! Glad you got it working !
Hi! Any idea how to format this query in postman itself?
