- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
Meraki Robust Transformer having issues and not loading data into CI table
I am running the Meraki Data Source - SG-MerakiDevices, and once the data gets loaded into the Data Source table, the Robust Transformer is failing and throwing the following error which I attached
Do we need to change anything in the Robust Transformer to get it to work? If so, what modifications are required?
Below are the references images for Datasource and Robust Transformer
Solved! Go to solution.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
I have no idea what this is about, but the issue is with an unexpected null.
Can you transform that into a 0 or something, or test for a null and act on that?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
This is happening while I am running Robust Transformer for Meraki Devices
I am trying to find which column is generating null, but not able to find it in logs..
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Is this about the ServiceNow graph connector?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Yes, It is Service graph Connector
i am trying to run SG-Meraki Devices Data source and after that triggering RobustTransformer but getting the above error
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Which version of the connector are you using?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Thanks. There’s a bug with v1.5 and a patch is going through the ServiceNow certification process these days.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Hopefully by the end of this week.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Version 1.5.1 of the ServiceGraph connector is now available in the ServiceNow App Store.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Thank you
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
The bug fix for Meraki ServiceNow Graph Connector has been released as v1.5.1. This update addresses specific issues encountered in version 1.5.0, including the "Invalid Entity class" and "Missing entity mappings" errors. To resolve these issues, we recommend that customers take the following actions:
- Upgrade the Meraki ServiceNow Graph Connector to version 1.5.1.
- Follow the instructions in the Setup Guide within the ServiceNow instance, specifically the step titled "Execute Fix Script." Please see the image below for details
Making any changes to the entity mappings or robust transform will cause errors even after upgrading this connector. If any changes are made to these mappings, please uninstall and reinstall the connector. Ensure that you follow all the steps in the guided setup accurately after installing again.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
