Meraki MR does not accept my static Lan IP with API
david11
Hello everybody
I am writing a script that sets the LAN-IPs for all the AccessPoints.
My problem is that the MRs that are in a network change their LAN-IP-Address to the static one but the MRs that are in no network and are still in the inventory do not apply the static IP-Address.
Is this normal or is there a problem with my api call?
That is my payload with IPs as x 🙂
payload = {
"wan1": {
"vlan": None,
"staticGatewayIp": "x.x.x.x",
"staticIp": x.x.x.x,
"staticSubnetMask": "x.x.x.x",
"usingStaticIp": True,
"staticDns": ["x.x.x.x"]
RaphaelL
To set a static IP on a device it has to be in a network.
This isn't the subject of your post , but why are you using static IPs. More trouble and no gain.
RaphaelL
+1.  Use DHCP for APs.
david11
Thanks for your comments and helping me.
@RaphaelL it is a requirement. I am just implementing it. 🙂
