When using the API to GET the MX 1:Many NAT rules, my output is incomplete. Instead of displaying the port rules the output displays portRules=System.Object[]
I am using powershell
I have read-only priveleges
My output (using fake IP's):
{publicIp=193.1.1.1; uplink=internet1; portRules=System.Object[]}
Documentation output:
publicIp: 146.11.11.13, uplink: internet1, portRules: [ { name: Rule 1, protocol: tcp, publicPort: 9443, localIp: 192.168.128.1, localPort: 443, allowedIps: [ any ]
any assistance is welcome
cheers!
Solved! Go to Solution.
I believe you get System.Object() when powershell doesn't know how to convert the object to a string. You are going to need to unpack it yourself first.
That sounds like a Powershell issue. Check out this article:
Thanks, PhilipDath, i will give that a go.
I thought I would try my hand at Powershell instead of my usual goto of Python
PS is certainly more challenging...
@PhilipDAth gave me a good direction to pursue, and made me think about the objects and output a lot more.
After a lot of trial and error, I was still not able to expand objects, which was frustrating.
So, instead, i went back to the method I was using to get the data from the meraki device
I was using Invoke-RestMethod, however, changed this to Invoke-WebRequest, which provided all of the details I needed
