Hi @dchenl337 , welcome to the Meraki Community! 😊
At the moment, "time based alerts" is not an available feature.
We take our customer feedback seriously and would encourage you to submit a feature request.
You can make a feature request by going to the bottom right-hand corner of any dashboard window and send the request through the "Give A Feedback" button.
Any wish that is made, sends an email to our Product Managers and Development Teams. These wishes are taken into consideration and are used to help shape our product roadmaps. The most wished-for items are incorporated into product development.
Coming back to your query…. There might be a workaround from the Freshservice end. I've read you might be able to set up time-based alerts in Freshservice by heading to Admin > Workflow Automator, creating a workflow for the "Alert" module that triggers when Meraki sends an alert, and maybe adding a condition to check if the "Current Time" is past something like 5 PM in your timezone. If it works, it could escalate the alert with a notification or something, but if not, it might just close it—I’m not totally sure on the specifics, though as I am not a Freshservice employee 😃!
If you found this post helpful, please give it kudos. If it solved your problem, click "accept as solution" so that others can benefit from it.
