I have issues with renaming the AP ( update Network Device) is not working for me
Farrukh
from meraki_sdk.meraki_sdk_client import MerakiSdkClient
from meraki_sdk.models.update_network_device_model import UpdateNetworkDeviceModel
from meraki_sdk.exceptions.api_exception import APIException
x_cisco_meraki_api_key = 'X-Cisco-Meraki-API-Key'
client = MerakiSdkClient(x_cisco_meraki_api_key)
devices_controller = client.devices
collect = {}
network_id = 'networkId4'
collect['network_id'] = network_id
serial = 'serial0'
collect['serial'] = serial
update_network_device = UpdateNetworkDeviceModel()
update_network_device.name = 'My AP'
update_network_device.tags = ' recently-added '
update_network_device.lat = 37.4180951010362
update_network_device.lng = -122.098531723022
collect['update_network_device'] = update_network_device
try:
    result = devices_controller.update_network_device(collect)
except APIException as e:
    print(e)
5 Replies 5
CptnCrnch
Most basic question: have you set your API key
correctly? Your question or better the way you‘re describing the fault doesn‘t make it easy to help you unfortunately. E.g. what response / error are you getting with this.
yes it is working now but not with the Python liberary
Are you getting an error message back?
And I'm guessing you have obfuscated the network id, since a real network ID does not look like that?
their is some issue with python library.
It is working with REST Call
