I'm working for an organization with a large number of Meraki networks and a massive amount of Meraki access-points.
and we want to create an overview of the capabilities(802.11b/g/n, ac or ax) of the wireless clients.
is there an easy way to get that with an API/Python script?
did you check the API documentation?
Under clients there is a call "getNetworkClient" which includes wireless capabilities.
hope this helps
roger
Hi....
Here a small piece of python
Yes checked the API documentation and seen the getNetworkClient.
But i was wondering i someone could help me with a python script which can go through the network
and find all wireless clients.
i'm new to python.
I know that feeling.... i wanna get rid of it too.....
If you find a solution to that... please share
