Get SM Network IDs
bunge
Get SM Network IDs
Hello! I'm having trouble running Get Organization Networks to return SM Network IDs. I can call Get Organization Networks just fine, but all SM networks are omitted.
Is there a different API endpoint I should be using that will return SM network IDs?
Thanks!
Ryan_Miles
Meraki Employee All-Star
Is the read only admin an org admin or just specific networks?
Ryan_Miles
I just created a new SM test network and the Get Org Networks endpoint returns the network ID for me.
https://api.meraki.com/api/v1/organizations/<my ORG ID>/networks
bunge
I wonder if this could potentially be related to API key permissions?
I am a SAML org admin, but the key I am using is that of an org read user.
Also if it helps I am using the Python SDK, calling:
mdm_network = dashboard.organizations.getOrganizationNetworks(meraki_org['id'])
Ryan_Miles
bunge
That was the ticket!
The read only admin was not an admin on the SM networks, only on the SD-WAN networks. After adding the appropriate network tags to the admin user, the API call now returns SM networks.
Thank you!
