Get Organization Appliance Uplinks Usage By Network 404 Error
JeenChew
Trying out the early access API "Get Organization Appliance Uplinks Usage By Network". This API gets uplink usage of all Networks in an Organisation. Using the same account/API key, it works on some Organisation but on others it is throwing up a "404 error".
Some Organisation doesn't have MX so it make sense that it might not work but some Organisations do have MX/Appliance but still showing error.
API details: https://developer.cisco.com/meraki/api-v1/#!get-organization-appliance-uplinks-usage-by-network
I am aware there is another API that gets this information on a Network level https://developer.cisco.com/meraki/api-latest/#!get-network-appliance-uplinks-usage-history but will need to run multi requests for an Org which a lot of Networks.
sungod
This is an Early Access call, you need to enable EA on the organization(s) you want to use it on, see...
https://developer.cisco.com/meraki/api-v1/#!api-reference-early-access-overview/early-api-access
2 Replies 2
sungod
JeenChew
thank you very much, this is it
