Generate a report or webhook for wireless roaming
CraigShaw
Just browsing
We want to create some type of report to show when clients are roaming between 5GHz and 2.4GHz. I have seen clients switch bands while staying associated to the same AP. We want to show a history of these events to possibly justify turning off the 2.4 for that SSID. Yes, we have band steering enabled. Etc..
6 Replies 6
You Should Use the Meraki API to Automate Bandwidth Roaming Reports.
Get Network Wireless Client Connection Stats - Meraki Dashboard API v1 - Cisco Meraki Developer Hub
Cisco Meraki Dashboard API - Cisco Meraki Documentation
Mloraditch
Webhooks only work off alerts so that won't be an option as there is no alert for this.
https://documentation.meraki.com/General_Administration/Other_Topics/Webhooks
As this is a point in time thing, I'm not sure of any API call that would help. The various client ones show active or last known info, but clients could be constantly moving.
However, This info is shown in the event log at every association
Ex:
So perhaps offloading logs to a syslog server and then you can filter for these events and analyze by client.
APIs would help, but you need to use a set of APIs to achieve this.
GET /networks/{networkId}/clients
GET /networks/{networkId}/wireless/clients/{clientId}/connectionStats
GET /networks/{networkId}/clients/{clientId}/usageHistory
So it will involve programming in the end.
Mloraditch
I guess it depends how accurate you want the data to be. Does that connection stats one actually show all the bands a client has used in the periods it allows? I feel like the others would need to be constantly polled.
You are right, but to get accurate and timestamped roaming data, you can use the event log (GET /networks/{networkId}/events). So you can use this API with a scheduled polling script and then store the data in a local database or CSV and analyze band switching patterns on the same AP.
It's not an easy task, but it should work fine.
Oren
Meraki Employee All-Star
The roaming analysis page in Dashboard would show you that information.
Regardless to the results, I’d recommend disabling 2.4GHz. It should be enabled on a dedicated SSID only so 5GHz clients won’t even try to connect to it.
Once upon a time I wrote this script to prove a point. It should still work.
