any issue on v1 for this PING api?
Example : https://api.meraki.com/api/v1/devices/Q2MY-4NJE-UVN5/liveTools/ping/604608250036435421
it used to work before 4 weeks , now it says page not found
can any one have an idea of what end point is changed for pING functions in v1 api?
What is the extra bit in your URL after /ping?
https://developer.cisco.com/meraki/api-v1/create-device-live-tools-ping/
The URL should look like:https://api.meraki.com/api/v1/devices/{serial}/liveTools/ping
Is the extra bit the ping ID from a prior call?
Ping results won't be kept forever, eventually the ID will expire and give a 404.
Hi @CiscoLumen the most common data retention period for items in dashboard is 1 month, so if it 404s after 4 weeks then that seems normal!
I'd recommend removing your serial number from the post above at your first convenience--it's generally best to not publish them.
