- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
GET OrgDevices - Devices Missing
Hello. First time using the Meraki API. I am conducting an assessment for a customer who has almsot 100 networks under their org. I would like to export inventory for the entire Org and I like the info that the API gives me versus the built in dash export tool (like including local IP for example).
The problem is that after running the API call named 'getOrganizationDevices' the list it returns is not completed. I have found random missing devices such as switches and MX devices. Does anyone have an idea as to why this may be happening?
Solved! Go to solution.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Like @alemabrahao and @RaphaelL say, results are returned in 'pages', for the endpoint you are using the maximum is 1,000 devices per page.
If you have more than 1,000 devices, you will need to follow the pagination rules to get the next page(s) of results, see...
https://developer.cisco.com/meraki/api-v1/pagination/
Ypu can use the script from @Jamieinbox or write one yourself using the Meraki Python library (it can handle the pagination for you)...
https://github.com/meraki/dashboard-api-python
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
I suggest you open a support case.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
How many devices do you have?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
If I perform an Organization export from the dashboard, I see 1,667 lines on the CSV file.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
It says per page. The number of devices per page doesn't really concern me. Does this mean it will not export every page?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Have you tried this one?
https://developer.cisco.com/meraki/api/get-organization-inventory-devices/
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
They will not help and will tell you that you need someone to do scripting.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Are the missing devices assigned to a network or, in your inventory but not assigned to networks
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
If I look through all devices (Org > Inventory) and search by Used and Unused, yes I do see devices not in a network.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
This will get all the APs (not Meraki switches or other gear) and place it into a spreasheet.
Merakicode/AssetDataDump at main · jadexing/Merakicode (github.com)
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
You have over 1K devices. You have to use pagination. The Meraki SDK already covers that.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Sorry but I don't really know what that means. Do you have a link that covers how I can resolve this?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
