We're preparing for the situation where quite soon we believe we're going to start hitting the 100 requests per IP API rate limit with some of our larger partners. When that happens, we're expecting to see a 429 and we'll handle that, but it would be very useful to have an additional header which told us if the 429 relates to the 10-per-Org limit, or the 100-per-IP limit. The reason this would be useful is we have additional mitigation options if the limit being exceeded is the per IP one.
Best
Martin
Did you check this thread?
API call budgets define the number of API calls that an API client can make in a given amount of time and are a safeguard against runaway applications and malicious behavior. Call budgets (or rate limits) are a standard feature of high performance APIs across industries and working within the provided call budget is table stakes for any developer building an application that consumes the API. The best practice is for applications to manage API call budgets effectively and avoid making API calls in excess of the limit.
https://developer.cisco.com/meraki/api/#!rate-limit
Hi, @alemabrahao, thanks for the reply. Sorry I don't understand. I'm not sure what the relevance of that thread is to my request? Could you explain please?
Martin
That does sound useful - but wearing a security hat, if I was Meraki I would not implement it. This information might be useful to an attacker.
@PhilipDAth That's an interesting point of view. I would have thought the risk would be minimal as you need a valid API key don't you?
I'm not sure the threat of a DOS attack is changed much by whether you have a valid API key or not (it depends on how resources are consumed), but I am just conjecturing on reasons why they might not do this. 🙂
In a perfect world, you would get rid of API limits.
