First of all, you may want to change the screenshot, as you are showing most of your API Key.
Second, you may want to use the getNetworkEvents endpoint instead. The one you are using, will only return your alert settings. Not the events themselves.
LinkedIn :::
https://blog.rhbirkelund.dk/Like what you see? - Give a Kudo ## Did it answer your question? - Mark it as a Solution
🙂All code examples are provided as is. Responsibility for Code execution lies solely your own.
