Ewelink Webhooks
JKlop
Ewelink Webhooks
I am attempting to integrate a Cisco Meraki MT30 Automation Button with an Ewelink Smart Switch via Webhooks. I have configured Ewelink Web to receive a Webhook but the Scene is not triggered although the web server tests seem to be working.
Has anyone completed integration with Ewelink Webhook ?
2 Replies 2
DexterLaBora
I have not used this service, but it seems like it should be doable.
Does the Ewelink scene trigger when you try using their webhook URL in a Postman request?
Do you know what the expected request body of the post should look like?
(their docs were pretty light)
If it turns out that you need specific headers or properties in the body, you can create a custom webhook payload template for this.
https://developer.cisco.com/meraki/webhooks/payload-templates-overview/
Dexter,
Thx for the info, I have contacted Ewelink support to supply additional information on POST request. Works with GET when the payload appended to the webhook URL as a query string.
