API scripting - Bulk creation and serial numbers
dan_cullen
I was wondering if anyone could help. I am trying to write Python scripts. One of the scripts I am writing is to create networks. I can't seem to find any Meraki API code that would allow me to create networks and assign serial numbers to the newly created network (Meraki MX for SD-WAN). You can if you manually use Bulk network creator but this may be closed of by Meraki when it comes to scripting. Any help would be great.
David_Jirku
A device (serial number) can only exist in one org. If you attempt to claim a device serial into the network which you don't have in the org inventory, you'll receive an error:
{ "errors": [ "Device with serial Q234-ABCD-0001 not found" ] }
If you attempt to claim a serial already in the network:
{ "errors": [ "Device with serial QXXV-FXXR-XXD7 is already claimed and in Test Network (network ID: L_9906373669455549372)" ] }
Otherwise, success is just a 200, OK; success.
The Meraki Dashboard will not allow you (or your API key) access to inventory that you don't have privileges for.
7 Replies 7
Have you checked it?
https://github.com/meraki/automation-scripts
dan_cullen
Thanks for the reply, but unfortunately it does not appear to have a create network, or update device with serial number. I can create networks with everything apart from the assigning serials of Meraki MX's to the network.
David_Jirku
You can claim a device from inventory into a network using the following endpoint:
https://developer.cisco.com/meraki/api-v1/claim-network-devices/
If they are not yet in inventory, you can use:
https://developer.cisco.com/meraki/api-v1/claim-into-organization-inventory/
dan_cullen
Thanks David, I have seen that but here is my worry, and please correct me if I am wrong. When you run this code it simply asks for a NetworkID. Which is fine, but I have 3 organizations. How does it know which organization it is for and does this just pull from the Meraki database not the inventory ? Just worries me a little
David_Jirku
John_on_API
Meraki Employee All-Star
Network IDs are globally unique, so org ID isn't needed.
dan_cullen
Funny story for you both, I was pulling and playing with the data and saw a network that was supposed to be in another organization pull through. I thought, Network_ID's must not be unique, only unique to the organization. Turns out, my work colleague was replicating the company in our lab so I was pulling through the correct one but it looked like the other. Thanks John and David for the advice. I am going to try all of the above today, much appreciated.
