- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
Error code 508
Hello, I am currently testing the dashboard API, what situation does 508 Error mean?
Error handling in Meraki developoper hub does not contain information about 508 error.
(https://developer.cisco.com/meraki/api-v1/errors/#error-handling)
It is not a case that occurs in a particular API, and even the same API appears intermittently on my application.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
The HTTP response codes are standardised, 508 is 'loop detected'. Indicating a service error or resource limit. I'd guess it'd be a transient error unless something is broken.
https://www.iana.org/assignments/http-status-codes/http-status-codes.xhtml
I don't think I've ever seen a 508 response from Meraki in years of heavy API use. Have you anything in your code that could issue high volumes of calls in a short period without following the rate limiting process?
Otherwise, if you are getting these responses only on one org, maybe open a support case to check if there's an internal problem specific to the org.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
I've never seen a 508 in years of light API use. 🙂
