Duplicate client records returned by getOrganizationWirelessDevicesPacketLossByClient
sungod
I was doing some testing and notice a problem with one of these new endpoints...
https://community.meraki.com/t5/API-Early-Access-Discussions/Now-in-beta-wireless-packet-loss-statis...
The 'by client' endpoint sometimes returns duplicate client records. I've tried it with/without a band filter, behaviour is similar.
Btw I do not see any duplicates on the 'by device' endpoint.
Without a band filter, there are sometime two or more identical records for the same client.
With band filters and consolidating data for the three bands, the duplication may occur on one, two or all three bands.
This org has > 40,000 clients in the sample period (September 2023), running for each band, over 6,000 network-client records have a least one duplicate in one or more bands, one has 20 in all three bands.
Number of copies per network-client-band, should only be 1 copy per unique network-client-band...
unique network-client-bandcopies
1147921
42992
9203
1884
2475
856
287
198
199
2010
1911
4312
5613
1114
1215
1816
2817
1918
1419
320
Sample with network and MAC hidden (any given client is on just one network, id-MAC are identical)...
periodidbandupTotalupLostupLost%downTotaldownLostdownLost%
2023-09k04037a2.4000000
2023-09k04037a5000000
2023-09k04037a6000000
2023-09k040e892.43036802.628552458.6
2023-09k040e89530909524730.859593071731.2
2023-09k040e896000000
2023-09k046f492.422001200
2023-09k046f495000000
2023-09k046f496000000
2023-09k0488f22.4994313.1860596.9
2023-09k0488f2520936420.22812421667.7
2023-09k0488f26000000
2023-09k0778862.4000000
2023-09k07788653651611.711041166115
2023-09k0778866000000
2023-09k0c52162.451003300
2023-09k0c52165000000
2023-09k0c52166000000
6 Replies 6
GreenMan
You should raise a case with Meraki Support for this, I think - if you didn't already.
sungod
I already have several cases open on other API issues, some open for a long time now.
As this endpoint is only just GA after a pretty short beta period, I would like Meraki to own it and look at the problem without me needing to open yet another case.
pharju
Hello! 👋 My team owns this API and are working on additional endpoints that serve metrics per-client. Filing a support case with specific examples regarding the network(s) where this occurs and the clients that are duplicated would be very helpful for us. 🙂
sungod
I opened case 10959729 it identifies an org where the problem occurs and also IDs of one of the networks/clients showing duplicates (there are many more).
sungod
Meraki support claim that it is correct for multiple identical client records to be returned and want to close the case.
sungod
I'm just getting the runaround from support now, it is exactly why I did not want to open a case!
