Does anyone know what time frame this device performance endpoint is for? I think it is for the last minute, but I was trying to confirm that: https://developer.cisco.com/meraki/api/#/rest/api-endpoints/devices/get-network-device-performance
Solved! Go to solution.
Here we go this should help explain the time and value reading.
https://documentation.meraki.com/MX/Monitoring_and_Reporting/Device_Utilization
I believe the default is 30 days.
That can't be true. I've got devices reporting "100" but the Org->performance overview barely shows 5. The API endpoint doesn't have a default documented or a way to change it, but it seems poorly documented.
Ah, thanks! That's exactly what I needed! 🙂
