Hello everyone,
with python i try:
>>> import meraki
>>> API = ********
>>>dashboard = meraki.DashboardAPI(API)
but raises an exception:
AttributeError: module 'meraki' has no attribute 'DashboardAPI'
I have the latest version 1.39.0
What I am doing wrong?
Thanks.
Solved! Go to Solution.
This attribute does not exist, what information do you want to extract from the Dashboard exactly?
If doens't exist, according to docs, how I will be able to have a response from as an example:
response = dashboard.organizations.getOrganizations()
if:
dashboard = meraki.DashboardAPI(API_KEY)
Thanks.
Maybe it will help you.
https://community.meraki.com/t5/Developers-APIs/Meraki-API-No-Attributes/m-p/151439
after you do
>>> import meraki
what is the output of
>>> dir(meraki)
and
>>> meraki.__version__
Follow this usage guide from the Meraki developer portal.
