Dashboard API for device availability.
Ritish
Is there any api for getting the info for device availability?
CBurkhead
You should be able to use GET /organizations/{organizationId}/deviceStatuses to retrieve the status of the devices in an organization. Anything that is not "offline" should be accessible.
2 Replies 2
CBurkhead
BrianP
Are you referring to Device Status?  If so @CBurkhead is correct and that call should be sufficient.  If you are looking for availability statistics like if a device is up for 99% of a time period, then they don't have a specific call for that.
You can use the GET /networks/{networkId}/devices/{serial}/lossAndLatencyHistory endpoint to get the packet loss info for a time period.  The inverse of that is close to availability (depending on the availability calc you are going for ).
