- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
DHCP Scope depleted via Syslog?
Who might be able or deny if Meraki MX make a syslog entry when either the DHCP Scope is depleted or when it cannot lease an IP to a client due to lack of available IPs?
I know there is an endpoint that provides this, but at scale it's too expensive to use against the Dashboard API rate limits.
Example API output. Can some provide a related event message example from the syslog?
Thanks so much.
Solved! Go to solution.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
I'd assume the "dhcp no offers" syslog event might also trigger. See...
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Easy to test. Created a /30. Plugged a couple devices and captured the MX screaming these logs :
Done on MX18.107.6
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Thanks. Based on this I found the event.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Also note that the "free count" that the API returns fails to take into account DHCP reservations. So it is very possible to have a "freeCount" and to have no DHCP addresses available.
You can test this easily by creating a DHCP scope, and then reserving the whole thing.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Thanks. This helps me to understand what I might be looking at where I'm seeing "dhcp no offers" in the syslog but the following endpoint shows a freeCount of 29.
https://api.meraki.com/api/v1/devices/[Serial]/appliance/dhcp/subnets
[{"subnet":"10.0.25.0/24","vlanId":0,"usedCount":224,"freeCount":29}]
I'm seeing this "dhcp no offers" event for the same mac address about every minute directly preceded by the following event types:
"wpa_auth" |
"association" |
"disassociation" |
"association" |
"wpa_auth" |
"disassociation" |
