Using APIs to add a RADSec server on WLAN.
Following doc:https://documentation.meraki.com/MR/Encryption_and_Authentication/RADSec_Support_on_MRs
https://documentation.meraki.com/MR/Encryption_and_Authentication/MR_RADSec
At the step of "Create the Organization Root CA", I am running into an issue, where the POST API call gives "404 Not
Found" for the URL: https://api.meraki.com/api/v1/organizations/<orgID>/certificates/radSec/deviceCertificateAuthority
I am attaching the postman screenshot. Can anyone help me figuring out what is wrong?
Solved! Go to solution.
as the other endpoints are working and you're following the published documentation, i think it'd be best to open a case with support
I don't think I'm seeing that endpoint in either the documentation or the current OpenAPI spec.
Is it a private endpoint beta ?
Thanks for the kind response. I am not sure what is a private endpoint. I just wanted to configure RADSec and the document wanted me to use APIs to upload the certificate, using the aforementioned URL.
@John_on_API Are these new endpoints related to RadSec GA yet ?
I don't think so. You can check in Interactive API Docs
In case it's because some endpoints are still not released, try enabling 'Early API Access' on the organization.
Look in Dashboard --> Organizations --> Early Access --> Early API Access
Good suggestion but i checked and Early API Access was already set to opted in.
