Hi all,
I want to read an SSID from one network and push it to another.
When reading it, I get an object/dict like the following:
{'authMode': '8021x-radius',
'availabilityTags': [],
'availableOnAllAps': True,
'bandSelection': 'Dual band operation',
'defaultVlanId': 999,
'dot11r': {'adaptive': False, 'enabled': False},
'dot11w': {'enabled': True, 'required': True},
'enabled': True,
'encryptionMode': 'wpa-eap',
'ipAssignmentMode': 'Bridge mode',
'splashPage': 'None',
'ssidAdminAccessible': False,
'useVlanTagging': True,
'visible': True,
'wpaEncryptionMode': 'WPA2 only'}
but to push it, the API wants all elements individually:
response = dashboard.wireless.updateNetworkWirelessSsid(
network_id, number,
name='My SSID',
enabled=True,
authMode='8021x-radius',
enterpriseAdminAccess='access enabled',
encryptionMode='wpa',
psk='deadbeef',
wpaEncryptionMode='WPA2 only',
This problem is more based on my miserable programming skills, but how do I pass this source dictionary to the API call?
