Config Templates settings
is it possible to read the config template settings?
I know you can get the config templates itself with "
GET /organizations/{organizationId}/configTemplates
And the result looks like this
[ { "id": "N_24329156", "name": "My config template", "productTypes": [ "appliance", "switch", "wireless" ] } ]
I've tried to get a list of devices with the id from this result as "network" id, but it is always empty. In this special case I'm interested in the appliance settings.
I want to read the local subnets settings and compare that to the ones which are used by the networks to get some kind of usage report.
Accepted Solutions
Re: Config Templates settings
I've added a new IDEA in the early developer community. API related wishes are getting more attention there.
If someone else needs that information, then there is some tricky workaround.
You can extract the subnet settings from the dashboard changelog and use the latest one.
10 REPLIES 10
I've done exactly this to retrieve network settings.
You do just as you say - treated the retrieve template ID and use it as a network ID.  Then you can retrieve all the settings.
You wont be able to retrieve information on specific devices - as a template doesn't contain actual physical devices.
Do you know how to get the address/vlan configuration over the api from the template?
Not specifically.  What happens when you use the normal API calls to retrieve the VLANs?
https://dashboard.meraki.com/api_docs/v0#vlans
Empty IP Addresses 😞
If you have auto-generated IP addresses, it won't pull those back for some reason.
The generated IP subnets are in the normal networks, so you should be querying the networks to get that info.
I'm not talking about the generated one. I want the address settings from which they are generated
Unfortunately it looks like you are out of luck.  Maybe use the make a wish function?
Good Morning,
We used templates as well, however due to some freak things, we were not able to autogenerate the VLAN IP addresses anymore. This really sucks... Also due to the nature of binding a network to the template, adding or removing stuff will result in errors.. Also later unbinding the template will have some effects on the current settings....
We in our organisation are not using templates anymore, and start using scripts to create networks and adding devices to that network...
The easiest way would be browsing through your route table but it is not really possible to find a free IP range, so i created a python script which browses though all the networks, creates a list of all used network subnets, and then picks one which is not in use.
