[Bug] Logging in to dashboard during OAuth flow does not redirect back and breaks OAuth flow
RCocks
This is a report of a problem that I've noticed only recently. I'm confident it used to work.
Currently if you start an OAuth flow while already logged into the meraki dashboard, you are presented with the organization selection and everything works.
If however you are not logged into the Merkai dashboard, then when you complete the login, then you are not redirected back to the OAuth organization selection. Instead, on logging in, you are placed at your dahsboard home, and the OAuth flow is broken.
The link back to as.meraki.com is in the "go" URL parameter at login, but this seems to be being ignored on login. ( Does it need allow-listing? )
Kind regards,
Richard
2 Replies 2
Oren
Meraki Employee All-Star
Thanks for reporting this. I am able to reproduce the issue.
For the sake of having it properly documented, can you open a support ticket please and share its number?
RCocks
Thanks @Oren , I've raised it as case  13649470 , I wasn't sure how to categorise it according to the help center, so I put it under "Dashboard Administration", because strictly speaking it's not the API itself.
