Adding admins to mulitple orgs
Jwiley78
After playing with Postman for a while I go it working some but it seems to be limited to one organization at a time.  I need something that will work with multiple organizations.  Mostly managing admin accounts for now and then move into other things later as time goes by.
I've tried this link and can't get it to work.  I think the links for the script are actually wrong and are pointing to something that has nothing to do with admin accounts.
https://developer.cisco.com/meraki/build/manage-administrators-across-organizations/
Anyone have any help or another route to try and do this.  If it I'm missing something and it can be done in postman then that would be great if not then I'm fine with learning how to use python.
3 REPLIES 3
Jwiley78
I think I found the right python script the above link was supposed to be referring to.  Now to try and get it to work.
https://github.com/meraki/automation-scripts/blob/master/manageadmins.py
AutomationDude
Hey @Jwiley78, if you're still having this problem then we do have a solution do it easily:
https://www.boundlessdigital.com/product/boundless-access-control/
Jwiley78
I ended up getting a python script to accomplish what I needed.  Thanks
