API call for organization client blacklist
AGoodman1
I apologize if this has been addressed but I could not find the answer searching the forums.
I'm looking for an API call to display all clients that have been blacklisted via wifi policy at the organization level, not a single site.
Any help is greatly appreciated.
RaphaelL
Hi ,
Not possible at the org level at the moment I'm afraid.
AGoodman1
Thank you for the quick reply,
Is there a call where I could specify the location and or perhaps a call to see blocked clients at the template level?
This is actually a horrendous thing to have to do at the moment.  This is a script I wrote to find all whitelisted clients in an org.  You can use the same thing to search for blocked clients.
#!/usr/bin/env python3
# meraki-list-whitelist-clients lists all the clients that have been "whitelist"
# (now called "allow list").
# Installation:
# meraki-list-whitelist-clients uses dotenv to safely store your credentials.  Create a file
# called .meraki.env in your home directory.  For Linux this is typically /home/username.  For
# Windows this is typically
# c:\users\<username>.
# Into .meraki.env put this line:
# MERAKI_DASHBOARD_API_KEY=<your API key>
# If you don't have an API key yet then follow the instructions on this page:
# https://documentation.meraki.com/zGeneral_Administration/Other_Topics/The_Cisco_Meraki_Dashboard_API
# Prior to running this script you'll need Python 3.x installed and you'll need to run the below
# commands to install the extra components required.
# pip3 install -U meraki
# pip3 install -U python-dotenv
# pip3 install -U throttler
# If you are using the script on Linux I would suggest marking it executable to make running
# it simpler.
# chmod +x mfw.py
# Usage:
# meraki-list-whitelist-clients.py -o "Your org name"
# History:
# When: 			Who:	What:
# 19/05/2023	PID		Completed original.
import os,argparse,asyncio,meraki.aio,throttler
# Load global and local Meraki settings such as MERAKI_DASHBOARD_API_KEY
from dotenv import load_dotenv
load_dotenv()
load_dotenv(dotenv_path=os.path.join(os.path.expanduser("~"),".meraki.env"))
# This function retrieves the netId
def getNetId(orgName,netName):
	orgId=None
	netId=None
	# Search for the org
	for org in dashboard.organizations.getOrganizations():
		if org['name'] == orgName:
			orgId=org['id']
			break;
	if orgId == None:
		print("Invalid organization name supplied: "+orgName)
		exit(-1)
	# Search for the network
	for net in dashboard.organizations.getOrganizationNetworks(orgId):
		if net['name'] == netName:
			netId=net['id']
			break;
	# If no network, search for a template
	if netId == None:
		for net in dashboard.organizations.getOrganizationConfigTemplates(orgId):
				netId=net['id']
				break;
	# Nothing found matching at all
	if netId == None:
		print("Invalid network name supplied: "+netName)
		exit(-1)
	return netId
# Check the policies for a client
async def checkPolicy(dashboard,netId,client):
	policies=await dashboard.networks.getNetworkClientPolicy(netId,client['id'])
	if policies['devicePolicy'] == 'Whitelisted':
		print(f"{client['mac']},{client['ip']},{client['description']}")
	elif policies['devicePolicy'] == 'Different policies by SSID':
		print(f"{client['mac']},{client['ip']},{client['description']},{policies['ssids']}")
# Search the org for potential whitelisted clients
async def searchOrg(dashboard,orgName):
	orgId=None
	netId=None
	for org in await dashboard.organizations.getOrganizations():
			orgId=org['id']
			break;
	if orgId == None:
		exit(-1)
	# Loop through all the networks
	for net in await dashboard.organizations.getOrganizationNetworks(orgId):
		print(f"Processing {net['name']}")
		if 'systemsManager' in net['productTypes']:
			print(' * Skipping - systems manager')
			continue
		clientTasks = [checkPolicy(dashboard,net['id'],client) for client in await dashboard.networks.getNetworkClients(net['id'],total_pages='all',perPage=500,timespan=30*86400)]
		for task in asyncio.as_completed(clientTasks):
			await task
async def main():
	# Meraki parameters
	orgName=None
	text="""
	meraki-list-whitelist-clients.py ...
	In your home diretory you should have a .meraki.env file containing MERAKI_DASHBOARD_API_KEY=<your API key>
	parser = argparse.ArgumentParser(description = text)
	parser.add_argument("-o", "--orgName", help="Meraki org name")
	args=parser.parse_args()
	orgName=os.getenv("orgName")
	if args.orgName: orgName=args.orgName
	if not os.getenv("MERAKI_DASHBOARD_API_KEY"):
		print("MERAKI_DASHBOARD_API_KEY must be defined in .meraki.env in your home directory or in .env in the current directory")
		exit(-1)
	if not orgName:
		print("orgName must be defined on the command line, in .meraki.env in your home directory or in .env in the current directory")
		exit(-1)
	async with meraki.aio.AsyncDashboardAPI(
		output_log=False,
		print_console=False,
		maximum_retries=100,
		wait_on_rate_limit=True
	) as dashboard:
		dashboard._session._concurrent_requests_semaphore = throttler.Throttler(rate_limit=4, period=1.0)
		await searchOrg(dashboard,orgName)
if __name__ == "__main__":
	asyncio.run(main())
