Hi all,
the subject says it ... I would like to change my LAN2 port on an MX67 to WAN2 to use it as the secondary WAN. But I don't find the corresponding API-call ... Any hints?
Hope you have all a great holiday-time, Karsten
Solved! Go to solution.
There is no such API endpoint today
Okay, next week is still ok … 😉
Hi Karsten, you can do this by using the updateDeviceManagementInterface API endpoint and set WAN2 as enabled. This will complet the conversion 😉
https://developer.cisco.com/meraki/api-v1/#!update-device-management-interface
Thanks, I'll directly test this!
Is there a way to do this for multiple devices at once? Kind of like the clone switch API endpoint but for the update device management interface?
This call needs the serial-number of the device. You have to get all the serials of all intended networks and iterate over this list.
