500 Errors on getOrganizationApplianceVpnStatuses
JGill
Anyone else seeing 500 Error with getOrganizationApplianceVpnStatuses
appliance, getOrganizationApplianceVpnStatuses - 500 Internal Server Error, retrying in 1 second
5 Replies 5
Ryan_Miles
Appears to work if using the networkIds parameter. Without that I get a 500 error like you. Not sure if it should work with no network ID. Maybe open a Support case and get confirmation.
Ryan / SE
JGill
Passing Just the OrgID and pages:
vpnstatuses = dashboard.appliance.getOrganizationApplianceVpnStatuses(organization_id, total_pages='all')
Has been working,  have a support case open on it.  May be shard related.
Found your Support case. Are you using v1? I just tried against your org and the call worked.
Also works against my org ID. I might have had v0 in call when I tested earlier. Or, something else was broke and magically got resolved within the past few minutes.
I also see the Support NSE just emailed you the same thing 😉
Ryan / SE
JGill
V1 on the API call.  Call's are working again, so assuming something on the backend got corrected.
RaphaelL
I'm getting HTTP 200's with api.meraki.com and with my Org shard ID. seems to be working fine for us.
